yawy Publicado 23 de Noviembre del 2006 Reportar Compartir Publicado 23 de Noviembre del 2006 Trasteando he encontrado esto. http://www.laserveil.com En esta pagina te intentan vender las bondades de un produco cuya fantastica propiedad es la de dificultar, la reflexion del haz de laser que usan para medir la velocidad. Estube leyendo bastante y dudas mucho de si funcionara o no, la cabeza dice que no lo hara y el corazon dice que quizas si. En definitiva en la propia pagina dicen que no es un producto magico que te vaya a hacer desaparecer las multas sino que mas bien es recomendable su uso en apoyo a otras contramedidas como inhibidores laser o cubiertas, para placas de matriculas, legales (en EEUU supongo que algunas seran legales) pongo un trozo en el que habla de eso "How does a VEILed license plate spray/covers coating perform?VEIL works by significantly reducing the reflection that occurs from today's high-tech retro-reflective license plates. These kinds of license plates effectively magnify the light that a police laser or photo lidar gun looks for. It is essential that VEIL (more a coating than a spray) is applied to any front-mounted state or personalized license plates to derive any real protection regardless of whether or not the other targeted sections of the vehicle are treated. Craig Peterson of RadarTest.com actually demonstrated the significance of the role plates play to your targetability with police laser. In areas where the use of a cover is prohibited, VEIL can directly applied to the plate. In these cases, it will appear darker. VEIL defeats laser by significantly reducing reflection and thus the overall laser visual signature by stealth. Since VEIL doesn't attempt to overwhelm incoming laser - simply eliminate it - it can not nor will not ever produce a jamming code on any police laser gun! Your vehicle will simply be much harder to successfully target and get a laser speed reading." Esto lo pongo porque se ha hablado muco de esos detectores laser que solo te avisan de cuando te estan enchufando con una pistola pero que son inutiles porque no da tiempo a frenar, pues bien en la propia pagina dicen que con esto esos aparatos son mas utiles porque mientras intentan pillar un sitio que les refleje la luz a ti te da tiempo a reducir la velocidad. Pues nada mas Ahi queda eso por si a alguien le parece interesante. Saludos Citar Enlace al comentario Compartir en otros sitios web More sharing options...
A300 Publicado 23 de Noviembre del 2006 Reportar Compartir Publicado 23 de Noviembre del 2006 En la Web de referencia:http://www.todoradares.com/web2007/otros_anti/veil.php Y con el buscador del foro...http://www.todoradares.com/foro/showpost.php?p=26061&postcount=11 Saludote. Citar Enlace al comentario Compartir en otros sitios web More sharing options...
yawy Publicado 23 de Noviembre del 2006 Autor Reportar Compartir Publicado 23 de Noviembre del 2006 Ya me parecia a mi raro que nadie lo hubiese visto antes... con lo contento que estaba yo de haber encontado algo que nadie conocia, en fin que la persona con capacidad para hacerlo que lo borre cuando estime oportuno. Saludos Citar Enlace al comentario Compartir en otros sitios web More sharing options...
juinta Publicado 23 de Noviembre del 2006 Reportar Compartir Publicado 23 de Noviembre del 2006 yawy te debo un mp, no me olvido... Citar Enlace al comentario Compartir en otros sitios web More sharing options...
