Thanks, good to know for when I do the AP7 in the other direction when returning home again! - Anteriormente
Nadie lo ha probado?
I am back in Spain and I noticed you also have some Poliscans on the AP7. Most of them were marked on Waze, but not all. I saw them on the first part when crossing the French/Spanish border. Do they have a visible flash in Spain? In Germany they have a visible red flash, in France they have a visible white flash, but I would think an infrared flash is also a possibility.
