Thanks for the information! Luckily I didn't see any flash. And the orange small boxes with "radar" mentioned on it, are these the Autovelox cabins? On the AP7 I saw a lot of these orange boxes on a stretch of road and they were alerted on Waze as a mobile radar, but no way that all of them were active since there were so many of them on a small stretch of road. - Anteriormente
Nadie lo ha probado?
REMOLQUE HOLANDÉS CON DAHUA
