Just because you didn't see it doesn't mean it wasn't there. You wouldn't be the first Neoline owner to get a speeding ticket. Neoline isn't a good product for Spain; it doesn't work well. - Hoy
"Circular" por el carril bus
Genevo Max, genevo pro2 or protector Enviado desde mi CPH2581 mediante Tapatalk
