CIRANO 670 can be detected with Genevo. What device are you using ? MRCT not present in Spain. - La semana pasada
ZENIT se unió a la comunidad
Puedes ir a CAVIAUTO como te indica Yester, es una buena opción en Lugo. -
Dagilo se unió a la comunidad
Moha se unió a la comunidad
Thanks for the extensive reply, it helps a lot! I still have some additional questions. - Is it correct that in Spain they only use MRCD and did not switch to MRCT like in the Netherlands? Currently I have MRCD and MRCT enabled, but the less I need to enable, the less false alerts I get. - Are there certain radars/lidars that are used more on the highway compared to other roads? You were talking about certain lidars that are used by local police, does the highway police have certain radars/lidars that they mainly use? Unfortunately my RD doesn't support Cirano 670 yet, but since it is not seen as mobile version yet on the roads I am not too worried about it for now. MRCD(/T), Dahua and of course Ka band are supported and enabled. And if I understand your post correctly, these are the most common mobile threats seen on the Spanish roads nowadays. - Anteriormente
Hufo se unió a la comunidad
Hi, I would like to know which mobile radars and mobile lidars are used in Spain nowadays. I can find a lot of info on this forum, but a lot of the posts are old. Fixed and mobile equipment are also mentioned mixed with each other. I don't care about the fixed equipment since Waze will warn me for it. I only care about the mobile equipment which Waze will miss if no one else marked it on Waze. I will take my radar detector to Spain and would like to know which frequencies I need to activate for the mobile radars. From the information I gathered I think this should be sufficient: Ka band 34.3 GHz ±100 MHz (mobile MN6F) MRCD (mobile MRCD) Laser (Velolaser, TruCAM II) Is this information complete and up to date? Which mobile equipment will I see the most? I am interested in general information about the radar/lidar equipment in Spain, but will be mainly driving around Almeria, Murcia and Alicante. Thanks!
