  1. La semana pasada
  2. Gracias por la respuesta. Un saludo!
  3. Thanks, good to know for when I do the AP7 in the other direction when returning home again!
  4. Sí, al PROTECTOR que ya tienes le podrás poner la doble antena (o quizás triple antena, y hasta aquí puedo leer ). Está previsto que para mediados o finales de julio esté todo listo. Esperamos recibir la primera muestra en los próximos días.
  5. @er_carde ¿Puedes actualizar de nuevo? Hemos liberado nueva versión que soluciona ese problema
  6. Normalmente los coches no permiten tener activas a la vez dos fuentes: o el bluetooth o el jack, no las dos y menos aún jugando con las prioridades (si no hay audio en una, reproduzca la otra). Un saludo
  7. Orange boxes are fake radars. Nothing inside, just a box made to look like one.
  8. Thanks for the information! Luckily I didn't see any flash. And the orange small boxes with "radar" mentioned on it, are these the Autovelox cabins? On the AP7 I saw a lot of these orange boxes on a stretch of road and they were alerted on Waze as a mobile radar, but no way that all of them were active since there were so many of them on a small stretch of road.
  9. Nadie lo ha probado?
  10. Buenas para cuando el de doble antena?.por otro lado tengo instalado un protector podria actualizarlo al de dos antenas
  11. Mensaje encriptado? [emoji6] Enviado desde mi iPad utilizando Tapatalk Pro
  12. Atranca el ventilador ese verás.
  13. hola, si efectivamente tanto en el mismo sentido como en sentido contrario
  14. Anteriormente
  15. Not only when crossing the border, but also even at 300 km far away. Here are using red flash like in Germany.
  16. I am back in Spain and I noticed you also have some Poliscans on the AP7. Most of them were marked on Waze, but not all. I saw them on the first part when crossing the French/Spanish border. Do they have a visible flash in Spain? In Germany they have a visible red flash, in France they have a visible white flash, but I would think an infrared flash is also a possibility.
  17. Buenas! LO MISMO AYUDO A ALGUIEN MÁS CON MI CONSULTA: Quiero que los avisos de mi Genevo Max se reproduzcan a través de los altavoces del coche con la ayuda de un emisor bluetooth con clavija mini Jack conectado en mi Genevo. Suelo llevar a través de bluetooth en el equipo del coche el móvil y sólo me permite una conexión bluetooth. Así que he pensado en otra clavija está vez receptora conectada a la radio del coche. Ambas clavijas emisor/receptor inalámbricos. De esta forma podría tener conectados a la vez vía bluetooth el móvil y vía Jack el Genevo a la vez, no? Cómo lo veis? Funcionaría? Alguien lo ha probado? Gracias y un saludo! Dejo un ejemplo de AliExpress a continuación: https://a.aliexpress.com/_EHQuCWQ
  18. Gracias por compartirlo!! Un saludo
  19. Buenas, Ayer me topé de frente con el famoso remolque con matrícula holandesa con lector de matrículas que han empezado a implantar en Cataluña (dicen en pruebas). Esta ubicado en la AP7 sentido Barcelona entre el km 184 y 185 justo un poco después de la entrada de la población St.Sadurní d'Anoia. Os dejo por aquí una muestra de que si detectan la banda DAHUA y su distancia de detección yendo a 120 km/h. VIDEO: https://www.swisstransfer.com/d/27b6542c-0a2e-4e1d-9d7e-14d177cfeb4b
  20. DAHUA??? Pasaste por el remolque holandés y te detectó DAHUA?? Ese remolque está pensado para control de matrículas, móvil, infracciones... y está en fase de homologación. Hay una versión con medición de velocidad también.
  21. Ahora lo estan utilizando en remolques portatiles en Cataluña. Lo curioso es que los remolques tienen matricula holandesa. Saludos
  22. Buenas! Acabo de adquirir el Genevo Max y me interesaría mucho el enlace de este video. Gracias!
  23. No hay nada que disculpar, faltaría más!! Se presupone, con toda la razón, que la prensa está para informar, pero ya ha demostrado muchas veces (y más en estos temas) que lo que hace es desinformar.... Un saludo
  24. Biel
    Nuevos radares DGT
  25. Por favor, no os creáis las cosas que publica la prensa. No tienen ni idea de estos temas y sólo buscan generar miedo y que se pinche en el enlace y se visite la web. Ninguna de esas fotos es España y ninguno de esos radares como tal existe en España. Los radares que han comprado son MultaradarCD para ir en trípode o instalados en vehículo. Lo único que hay real en esa noticia es el fabricante (Jenoptik) que es el fabricante del MultaradarCD. Así que Genevo MAX pita perfectamente frente a esos radares porque de "nuevos" no tienen nada. Por otro lado, no se puede "inventar" algo que mejore la detección láser por simple principio físico: No se puede detectar lo que no hay. Si el láser no ilumina no se ve y no se detecta. El láser sólo se refleja en una única dirección, no en todas como una onda. Sólo se puede utilizar un inhibidor. Un saludo
  26. Biel
    Nuevos radares DGT
  27. No hay ningún problema. Recuerda que lo que es ilegal es "conducir un vehículo que porte un detector de radar". El hecho de llevar un detector de radar andando en la mano, en el avión o en un barco, no es ilegal.
