CIRANO 670 can be detected with Genevo. What device are you using ? MRCT not present in Spain. - Ayer
ZENIT se unió a la comunidad
Puedes ir a CAVIAUTO como te indica Yester, es una buena opción en Lugo. -
Dagilo se unió a la comunidad
Moha se unió a la comunidad
Good questions, and you’re right a lot of the information online about Spain is outdated and makes it confusing. What you listed is mostly correct, but it is not completely exhaustive. In Spain, Ka band 34.3 GHz (Multanova 6F) is still in use and you will continue to see it . MultaradarCD (MRCD) is currently the most common mobile radar in Spain. It is used in patrol cars, parked vehicles and on tripods. DAHUA radars are also present. These are K-band, modulated radars and can be deployed both fixed and mobile on tripods. They are not as widespread as MultaradarCD yet, but their presence is growing and they are definitely part of the current landscape. CIRANO 670 radars exist in Spain and are already installed in fixed locations. At this moment, there are no visually confirmed mobile deployments on the road, but the technology itself exists and is active in the country. Regarding laser enforcement, it represents around 15% of total radars in Spain. Velolaser is used on tripods, inside vehicles and in very discreet setups. TruCAM and TruCAM II are used by local police, Mossos (Catalonia) and Ertzaintza (Basque Country). Classic handheld laser guns such as Ultralyte are also still used (Local Police in Madrid). In addition to those, there are still some Autovelox units in service. They are much less common than in the past, but a few remain and can still be encountered. Have a good trip and enjoy our country! - Anteriormente
Hufo se unió a la comunidad
Antes había una una opción que ya no veo, que me avisaban al email si el coche recibía un golpe o algún movimiento.
