Moha se unió a la comunidad
Thanks for the extensive reply, it helps a lot! I still have some additional questions. - Is it correct that in Spain they only use MRCD and did not switch to MRCT like in the Netherlands? Currently I have MRCD and MRCT enabled, but the less I need to enable, the less false alerts I get. - Are there certain radars/lidars that are used more on the highway compared to other roads? You were talking about certain lidars that are used by local police, does the highway police have certain radars/lidars that they mainly use? Unfortunately my RD doesn't support Cirano 670 yet, but since it is not seen as mobile version yet on the roads I am not too worried about it for now. MRCD(/T), Dahua and of course Ka band are supported and enabled. And if I understand your post correctly, these are the most common mobile threats seen on the Spanish roads nowadays. - La semana pasada
Hufo se unió a la comunidad
LANE X desactivado por el momento. Además, si no te mueves por Barcelona, de momento no hace falta. Este radar sólo está allí. Un saludo - Anteriormente
Hemos modificado el archivo de audio y corregido esa voz. Ya está cargado en el servidor, podéis actualizar para cargarlo. Un saludo
