Good questions, and you’re right a lot of the information online about Spain is outdated and makes it confusing. What you listed is mostly correct, but it is not completely exhaustive. In Spain, Ka band 34.3 GHz (Multanova 6F) is still in use and you will continue to see it . MultaradarCD (MRCD) is currently the most common mobile radar in Spain. It is used in patrol cars, parked vehicles and on tripods. DAHUA radars are also present. These are K-band, modulated radars and can be deployed both fixed and mobile on tripods. They are not as widespread as MultaradarCD yet, but their presence is growing and they are definitely part of the current landscape. CIRANO 670 radars exist in Spain and are already installed in fixed locations. At this moment, there are no visually confirmed mobile deployments on the road, but the technology itself exists and is active in the country. Regarding laser enforcement, it represents around 15% of total radars in Spain. Velolaser is used on tripods, inside vehicles and in very discreet setups. TruCAM and TruCAM II are used by local police, Mossos (Catalonia) and Ertzaintza (Basque Country). Classic handheld laser guns such as Ultralyte are also still used (Local Police in Madrid). In addition to those, there are still some Autovelox units in service. They are much less common than in the past, but a few remain and can still be encountered. Have a good trip and enjoy our country! - Ayer
Hufo se unió a la comunidad
No te aparece porque tienes activado el arranque por contacto y por giroscopo. Si está activo el arranque por giroscopo, la opción del "centinela" está desactivada puesto que un movimiento o vibración con el motor apagado (justo lo que controla el centinela) enciende el equipo. Arranque por contacto = Centinela comprueba si hay movimiento o vibración con el motor apagado. Puedes recibir alerta de motor arrancado y/o de movimiento no autorizado (con motor OFF). Arranque por giróscopo = Centinela se encarga de encender el equipo. Puedes recibir alerta de coche en marcha. Un saludo - Anteriormente
A mi el otro dia me pararon con un genevo one m puesto, y el policia o estaba de muy buen humor o estaba ciego porque lo quite delante de su cara y lo deje en el asiento del copiloto. Encima, del susto que me lleve pulse los botones que no eran y no borre el firmware :') . Si que es cierto que yo tendria pensado un plan por si me paran, y practicaria de vez en cuando quitar rapidamente el detector y borrar el firmware, pero luego hay que verse en la situacion
