Thanks for the extensive reply, it helps a lot! I still have some additional questions. - Is it correct that in Spain they only use MRCD and did not switch to MRCT like in the Netherlands? Currently I have MRCD and MRCT enabled, but the less I need to enable, the less false alerts I get. - Are there certain radars/lidars that are used more on the highway compared to other roads? You were talking about certain lidars that are used by local police, does the highway police have certain radars/lidars that they mainly use? Unfortunately my RD doesn't support Cirano 670 yet, but since it is not seen as mobile version yet on the roads I am not too worried about it for now. MRCD(/T), Dahua and of course Ka band are supported and enabled. And if I understand your post correctly, these are the most common mobile threats seen on the Spanish roads nowadays. - Ayer
Good questions, and you’re right a lot of the information online about Spain is outdated and makes it confusing. What you listed is mostly correct, but it is not completely exhaustive. In Spain, Ka band 34.3 GHz (Multanova 6F) is still in use and you will continue to see it . MultaradarCD (MRCD) is currently the most common mobile radar in Spain. It is used in patrol cars, parked vehicles and on tripods. DAHUA radars are also present. These are K-band, modulated radars and can be deployed both fixed and mobile on tripods. They are not as widespread as MultaradarCD yet, but their presence is growing and they are definitely part of the current landscape. CIRANO 670 radars exist in Spain and are already installed in fixed locations. At this moment, there are no visually confirmed mobile deployments on the road, but the technology itself exists and is active in the country. Regarding laser enforcement, it represents around 15% of total radars in Spain. Velolaser is used on tripods, inside vehicles and in very discreet setups. TruCAM and TruCAM II are used by local police, Mossos (Catalonia) and Ertzaintza (Basque Country). Classic handheld laser guns such as Ultralyte are also still used (Local Police in Madrid). In addition to those, there are still some Autovelox units in service. They are much less common than in the past, but a few remain and can still be encountered. Have a good trip and enjoy our country! - La semana pasada
Hufo se unió a la comunidad
En principio con que entréis con la cuenta que tenga asociada el equipo, debería aparecer. Voy a investigar las configuraciones por si viera algo que falta. Os mantenemos informados. Un saludo
