Hi, I would like to know which mobile radars and mobile lidars are used in Spain nowadays. I can find a lot of info on this forum, but a lot of the posts are old. Fixed and mobile equipment are also mentioned mixed with each other. I don't care about the fixed equipment since Waze will warn me for it. I only care about the mobile equipment which Waze will miss if no one else marked it on Waze. I will take my radar detector to Spain and would like to know which frequencies I need to activate for the mobile radars. From the information I gathered I think this should be sufficient: Ka band 34.3 GHz ±100 MHz (mobile MN6F) MRCD (mobile MRCD) Laser (Velolaser, TruCAM II) Is this information complete and up to date? Which mobile equipment will I see the most? I am interested in general information about the radar/lidar equipment in Spain, but will be mainly driving around Almeria, Murcia and Alicante. Thanks! - La semana pasada
No por eso he lanzado las preguntas. A ver qué nos comentan
